I´m trying to install Dynamics AX (client, debugger and bussines conector) but when installer is about to finish simply it stops responding.
I have windows 7 professional, spanish configuration. I have installed the .net framework 4.0 , I tried compatibility with XP , Vista etc (properties for the installer) but it didn’t work.
At the end I reach install Dynamics AX, Simply I noticed that although the installer stops responding , AX appears in start menu; so I opened it and after the installer ends successfully.
Previously I had finalized the installer (after 3 hours or more) although AX was in start menu (I did’nt open it), when I finalized the installer from task manager the installation failed (with a message Client, debugger and Bussines connector was’nt installed) and AX and AX Debugger desappeared from the star menu.
Well this is a detail that I hope be useful for someone.
