Dear ,
i installed the following on Ax2009
AX
SP1
RU 3
Process manufacturing
Full scope fix
RU 8
RU 8 process last sent by MS consultant
and when i Compile application,i faced the following error
1-\Classes\TaxLedgerJournal\calcAndPost 130 23 create a new method (local perhaps) to replace some redundant code.
2- \Data Dictionary\Tables\CreditCardAuthTrans\Methods\initValue 7 3 Delete the entire method when the code is move to the SYS layer, method must remain while in SYP layer
3-\Data Dictionary\Tables\CreditCardProcessors\Methods\isUSDOnlyProvider 12 7 remove this method once the code is moved into the SYS layer
4- \Data Dictionary\Tables\CreditCardProcessors\Methods\validateAccountForUSDProviders 18 7 remove this method once the code is moved into the SYS layer
5- \Data Dictionary\Tables\CreditCardProcessors\Methods\validateCurrencyForUSDProviders 15 7 remove this method once the code is moved into the SYS layer
i need help
to fix them plzzzzzzzzzzzzzzzzzz.
