Ax Client Connection Problem R6002
AX 2009.
I installed client on windows 7 workstation. When I run client I get an error ‘Runtime error! R6002 floating point support not loaded’. I tried reinstalling client but no use.
If I run the client as administartor then I don’t get any error & runs smoothly.
Pl tell me what is wrong with the installation.
ushetty
Try giving Admin(full) rights to the user from which u were trying to Log in previously.
No luck. It is already a member of administartors.
Try this link.
http://www.articlewritingclicks.com/Windows_Errors/Runtime_Error_r6002_Floating_Point_Support_not_Loaded__Repair.html
Try this link
Hope it might help you.
Still the same problem. Also I am able to run the client if I “run as administrator”
ushetty
