hi
i use ax 2012 i install clint in one location and server is in other location
i have data sync problem
my test connection is fail when i check clint part
can anybody help me
thanks
satiram
hi
can anybody help me
thanks
satiram
Can you please elaborate your problem ?
What are the error messages you are getting ? more details needed
sir Im having data syncronisation problem
test connection fail error display in my clint ax
pl pl give me the solution sir
connectivity to my server and clint not establish
what to do pl give me the way
thanks
satiram
Please, give us more information. Does it work from other locations, such as if you connect directly from the machine with AOS? If not, is your AOS service running?
If it doesn’t work from the particular location only, first check if you’re connecting to the right AOS server. Make sure that your client computer in in the domain and no firewall is blocking the connection.
Satiram, I deleted your replies about POS jobs, because they don’t belong to this thread. Please create a new thread for it, with an appropriate title and tags.
Also, you still didn’t give us more details about this question, so we can’t help you. If you’ve already managed to resolve it, please let us know so this thread can be closed. Otherwise do your part and provide necessary information.
