AX 4.0 application interface is appearing in code form.
Hi all, In ax 4.0 application interface all the names are appearing in a code form, for eg: Accounts receivables name is appearing like @SYS101692. What could be the reason and what is the solution for it.? Can anyone help me to solve this.
Regards
kalasagar V
Hi Kalasagar,
Check whether labels are deployed (.ald files) under Application directory.
If labels are deployed correctly, try stopping AOS, delete label index files (.ali) and restart AOS.
Last but not least, similar issues were discussed many times here. Please search.
Hi Harish,
Thank you very much for acknowledging me and for your valuable suggestion.
