I have created a new company within the Contoso system and having the following problems
- I have setup all of the relevant number sequences, I believe
However, created a sales order and trying to confirm this and getting the following error:
Numbers could not be generated because a number sequence reference is missing. Ensure that all necessary number sequences are set up.
Removal of suspension of recId allocation for table SalesParmLine has failed.
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Dynamics.Ax.Application.SysRecIdSequence.Removerecidsuspension(Int32 _tableId) in SysRecIdSequence.removeRecIdSuspension.xpp:line 23
at Dynamics.Ax.Application.formletterParmData.Removerecidsuspension() in formletterParmData.removeRecIdSuspension.xpp:line 15
at Dynamics.Ax.Application.formletterParmData.Catchall() in formletterParmData.catchAll.xpp:line 9
at Dynamics.Ax.Application.formletterParmData.Createdata(Boolean _append, Boolean ) in formletterParmData.createData.xpp:line 63
at Dynamics.Ax.Application.SalesFormletterParmData.executeChooseLinesServer(Object[] _salesFormletterContractPacked, Boolean _append, Boolean _reuseParmUpdate, Boolean _onlyCreateParmUpdate, Boolean _executeLateSelection, Boolean , Boolean , Boolean ) in SalesFormletterParmData.executeChooseLinesServer.xpp:line 22
at Dynamics.Ax.Application.SalesFormletterParmData.chooseLinesServerIL(Object[] _inputContract) in SalesFormletterParmData.chooseLinesServerIL.xpp:line 6
at SalesFormletterParmData::chooseLinesServerIL(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.SysDictClass.invokeStaticMethod(Object[] _params) in SysDictClass.invokeStaticMethod.xpp:line 26
at SysDictClass::invokeStaticMethod(Object[] )
at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog)
AM I MISSING A NUMBER SEQUENCE ANYWHERE IF SO WHERE PLEASE
THANKS
