I installed AX 2012 for Retail successfully. I can see the complete Retail module inside AX 2012.
I created Retail database using Retail Database Utility. I can see all the relevent table in SQL Express. I checked the log file which showed no error.
Now, when I am trying to open Retail POS I am getting the error related to the Configuration file. The Error message is hereunder :
Please advise in case i am missing any steps or I need to perform any additional step.
I checked with event viewer and I got the following error.
“The description for Event ID 110 from source Dynamics .NET Business Connector 6.0 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.”
I installed .NET Business connector while installing AX 2012.
