Hi. I am a newbie to AX 2012 reports and I was wondering how I can add expiry dates to the sales confirmation report in AX 2012. I was able to use old school display methods for 2009 but not sure how to do that in 2012. Please tell me the steps. Thanks
Hello,
Assuming these fields are not available in temporary tables, you may have to make following changes -
- Inside AX - Modify temporary table to add these fields and modify data provider class to populate these fields
- Outside AX - modify the SSRS report to incorporate these fields and deploy the report.
Please note - you may have to debug AX to figure out temporary table and the class.
Hi Harish. Thank you for your reply. Do I need to create a new method in the SalesConfirmDp class? Can you provide a code snippet example so I understand the logic? Thanks
You don’t need to create new method in this class. Try the following -
- Required field(s) in temporary table;
- Modify either ‘setSalesConfirmDetailsTmp’ and setSalesConfirmHeaderTmp’ method suitable for your requirement.
- Modify SSRS report to display these fields
- Don’t forget to generate full CIL (if you never did this before) or Incremental CIL (only if you regularly update your CIL)
