AX 2012 RDLC Report Deployment Error
Hi
When we try to deploy the RDLC report from Visual Studio 2010,Its giving the error as
Error 2 An error occurred : Access is denied.
If User Account Control (UAC) is enabled on the machine, close the application, right-click the application, and then click Run as administrator. C:\Program Files\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 466
Error 3 The deployment was aborted. You do not have privileges to deploy to server: xxxx. For deployment, you must have administrative rights to the SQL Server Reporting Services (SSRS) server. Contact your administrator to deploy. C:\Program Files\MSBuild\Microsoft\DynamicsTools\Microsoft.Dynamics.Framework.Design.Reporting.Modeling.targets 466
Can anyone pls. suggest a solution ?
It looks like as if you haven’t got that much user rights on the SSRS Server. Can you make yourself as a local admin on the SSRS machine? Or let’s say, start by checking what user rights you have got for the SSRS instance - can you open the URL of the SSRS Report Manager? If you can, check if you have sufficient rights to be able to deploy (Publisher or Content Manager).
http://beyondrelational.com/modules/12/tutorials/26/tutorials/4605/getting-started-with-ssrs-part-7-user-roles-and-permissions-in-ssrs-server.aspx
Thank you Janis for your reply,
Nice Post Even my error got resolved.
I also tried faced authority changed to the same problem, but could not be resolved.
if AOS side of the problem, you start the “Remote Registry” service.
