Demo data in ax 2012 r3 is not successfully imported.
when imported the demo data in ax 2012 r3, it ended with 13 error and cannot find demo data for vendors and customers so on.
please find the attachment and give some suggestion how to import demo data without errors.
this is what I got after completing demo data.
The message says where exactly you find the log file with details. Please look inside; it should tell you why import failed for some tables.
Thanks for your reply Martin.
In log file, it is there as \ Filtered by tool.
please help me on this.
Can you please share the full content of the file (DPLog.xml)?
Hi Martin Thanks for reply,
data is available in other company, will use that.
In DAT not available.
Thanks a lot
Martin
