Greetings,
I would to know from where I can download the CU9 update files…which I can copy in the “Update” folder under AX 2012 r3 source.
Hope with this, the CU9 update will also get included in the AX 2012 r3 installation.
regards
Greetings,
regards
Greetings,
I found the CU9 SlipStream.
You need to create a project in LCS and then initiate Update from thr. Slipsteam is required for fresh installation.
Thanks!!
