i have installed ax 2012 r2 ,while i am starting the services i have got an error 90.
"windows could not start microsoft dynamics ax object server 6.2$01-microsoft dynamics ax on local computer .for more information ,review the system event log .if this is a non microsoft seviece,contact the service vendor,and refer to service specific error code 90 "
Please give the solution as soon as possible.
Thanks& Regards,
Sudha.p
As I mentioned in my previous post, did you check Event viewer in AOS box? In 99.99% cases, there must be an error entry. Did you find that entry and did that make sense?
Sometimes you may have to check Event viewer in SQL box as well.
Object Server 01: Dialog issued for client-less session 1: The file ‘axgls.aod’ does not contain the correct check digits.
This is normally caused by file errors or by mixing different application versions.
Object Server 01: Dialog issued for client-less session 1: Error in file: D:\Program Files\Microsoft Dynamics AX\50\Application\appl\DynamicsAx1\axglsen-us.ahd while reading in record = 0
Windows error: =
Error code: 38 = Reached the end of the file.
Object Server 01: Dialog issued for client-less session 1: Error in file: D:\Program Files\Microsoft Dynamics AX\50\Application\appl\DynamicsAx1\axglsen-us.ahd while reading in record = 400
Windows error: =
Object Server 01:
Dialog issued for client-less session 1: Error in file: D:\Program Files\Microsoft Dynamics AX\50\Application\appl\DynamicsAx1\axglsen-us.ahd while reading in record = 0 Windows error: = Error code: 38 = Reached the end of the file. Try again?
Object Server 01:
Dialog issued for client-less session 1: Error in file: D:\Program Files\Microsoft Dynamics AX\50\Application\appl\DynamicsAx1\axglsen-us.ahd while reading in record = 400 Windows error: = Error code: 38 = Reached the end of the file. Try again?
Object Server 01:
Object Server 01:
Dialog issued for client-less session 1: The file ‘axgls.aod’ does not contain the correct check digits. This is normally caused by file errors or by mixing different application versions. A backup of correct files should be restored to avoid further damage. Microsoft Dynamics cannot be executed.
Object Server 01:
Object Server 01:
Object Server 01:
Object Server 01:
Object Server 01:
Object Server 01:
Dialog issued for client-less session 1: The message for ID 1390 cannot be found. Verify that your Microsoft Dynamics installation has the correct message file (*.ktd).
Object Server 01:
Dialog issued for client-less session 1: The message for ID 1389 cannot be found. Verify that your Microsoft Dynamics installation has the correct message file (*.ktd).
Application or service ‘Microsoft Dynamics AX Object Server 6.0$01-MicrosoftDynamicsAX’ could not be restarted.
Object Server 01:
[Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid object name ‘SYSCLIENTSESSIONS’.
UPDATE BATCH SET RETRYCOUNT=(RETRYCOUNT+?),STATUS=?,MODIFIEDDATETIME=?,RECVERSION=? WHERE ((STATUS=?) AND (RETRYCOUNT<RETRIESONFAILURE)) AND NOT EXISTS (SELECT ‘x’ FROM SYSCLIENTSESSIONS T2 WHERE (((BATCH.SESSIONIDX=T2.SESSIONID) AND (BATCH.SESSIONLOGINDATETIME=T2.LOGINDATETIME)) AND (T2.STATUS<>?)))
While Lauching the Application, I’m getting below error:
Conection with AOS could not be established.
I’m getting below error in Event Viewer :
The Microsoft Dynamics AX Application Object Server is running on an operating system that is not supported. The supported operating system is Microsoft Windows Server 2003 with Service Pack 1.
Same error for me also did u solve this error plz help me
After connecting Demo Database in SQL server then i started the service Microsoft Dynamic AX Object Server 6.2$01-MicrosoftDynamicsAX in AX2012 server but its didn’t start giving error :-
