AX 2012 R2 Database restore.
Hi
need help on below issue.
Live server: AX setup in 3 servers-> 1 AOS, 2. Database, 3.portal & reporting.
Test server : Single server setup.
take back from Live and restored back in test server. after that updated USERINFO table for user & domain.
But here AX is opening But no modules are coming. says no module selected. and share point site also not working.
Kindly Guide me how to resolve this issues. or i need to do any other changes after restore database.
samuel.
There are quite a few things regarding Enterprise Portal that you may need to change. Check out the document attached to Moving between Microsoft Dynamics AX 2012 Environment
Regarding modules, what is the exact wording of the error message?
