AX 2012: Maximum Inventory On Hand
What’s the best way to enter the maximum quantity for Inventory in AX 2012 r2? This is solely for information of user only & we will not be using masterplanning.
Bella
Dear Bella,
this use of maximum quantity is to restrict user to make PO for the item more then the maximum qty specify.
so check with your user and on basis of that define in the system.\
if your AX is in live production then get the statistics of the items and accordingly you define.
and best way is to check with budget control for the procurement and then u can define the qty also.
Hi Husain,
Thanks for the prompt reply. I just want to verify, it will NOT consider the stock on hand?
Bella
Hi Bella, You can define min/max quantity for each item w.r.t inventory management. There are various other item/warehouse/order setting based on requirement. Can you put up your query with more details. Thanks Gaurav
Bella
If you are not running Master Planning then on hand stock is irrelevant - set the maximum against a Min/Max coverage group in the item coverage settings and it is there for you to report upon. If you were using MP it would not matter anyway, you need more than the Max it will still order them and you could decide on the plan whether to include inventory or not etc.
Thanks, Gaurav/Adam.
We tried to set the max in item coverage but it is disabled. We can enter only info in Minimum.
Thanks.
This is because your coverage code is not set to Min/Max this is the only type that sets the Maximum.
Do not think it is an apt policy in most cases, so you have to understand why you want to define a Max of stock to HOLD (Note not order).
Adam is correct , but please do take care of stock dimensions while setting up item coverage.
Thanks, Guys.
I’ll try to do it on our test environment & see if this will suffice our reequirement.
Bella
