I have a requirement to import Exchange rate using standard Ledger Exchange rate service available in Ax2012.
I am using Create action, but however when Import the currency pair let us say USD to GBP first time with exch rate 0.814 for 24th April 2013 it imports correctly as this currency pair did not exist in the system.
Later when I import the same as above for date 25th April, the system throws error saying the currency pair USD to GBP already exists.
Have anyone used this service and can share some info of how they have used?
To import & Update exchange rates to Ax 2012 you first need to Create/Configure “Exchange Rate Provider” that exists within Ax built in Using “Exchange Rate Framework”, Please find the following link that has a downloadable of Microsoft provided white papers that explains step by step how to configure it and consume the updated exchange rates from the external providers.
For Ax 2012 R2 we can configure directly from form level in GL->Setup->Currency-> Configure Exchange Rate Providers. follow the below link that explains step by step process to setup
Were you able to find any solution for this. did the standard ledger exchange rate service work for you . were you able to update the record the subsequent time. Iam also trying to do the same and have the same issue… Any updates would be helpful.
