Hello Friends,
Now i am installing Reporting services extension in AX 2012. When re validate prerequisites i got an error
I have already installed SQL server 2008 R2 SP1 , SQL server 2008 SP1 after that error has occured
Please help me…
Hello Friends,
Please help me…
it is asking for updates for sql server.
click on error infront of that error message. you will get a link to download the required component.download that update and install afetr that restart the machine.
if that error link is not guiding to any downloads, share that window with us. so that we can suggest you some steps to follow.
hope that above solution will work…
Hi ,
Click on Link → Download ‘DynamicsAX2012-KB2709934’
Update this for DataBase… → Revalidate …Error wil be gone…
Tnx
Lakshmi…
Hello all,
I already follow the error link and download DynamicsAx2012-KB2709934 and revalidate this.
again this error has occurred…
Hi ,
Are you install this hotfix 'DynamicsAx2012-KB2709934 ’ for all modules .??
tnx
Lakshmi…
Hello Lakshmi,
As per your suggesition i am installing 'DynamicsAx2012-KB2709934 hotfix and solved my error.
Thanks a lot lakshmi.
But, Now i am installing Analysis services then i got an error …
Hi
Restart ur system after that u will try to install ‘Analysis Services’…
Tnx
Lakshmi…
Yes, Restart my system before installing the analysis services but error has occured.
please help me…
Do Like, Under Install → select Components , Analysis services configuration checkbox and Management Utilities check box-> next → Prerequisite Validation …
Tnx
Lakshmi…
hi,
follow all steps but error not solve.
Please help me…
Hi ,
Have u selected Correct Server Name and DataBase name ??
Tnx
Lakshmi…
Regain this : http://daxdilip.blogspot.in/2011/09/step-by-step-installation-dynamics-ax.html
Tnx
Lakshmi…
errors:
1. Microsoft SQL Server Analysis Services → Install a supported version of the Analysis Services component of Microsoft SQL Server. For information about the versions of Microsoft SQL Server that are supported with Microsoft Dynamics AX, go to http://go.microsoft.com/fwlink/?LinkID=165377. Note: When you use the standalone prerequisite utility, prerequisite checks are run on the current computer only. If you are checking prerequisites for the business intelligence components of Microsoft Dynamics AX, and Analysis Services and Reporting Services are installed on separate computers, the Reporting Services checks will fail on the Analysis Services computer and vice versa. Make sure that you run the prerequisite utility on each computer to make sure that the appropriate prerequisites pass. For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at http://go.microsoft.com/fwlink/?LinkId=211990.
2. Microsoft SQL Server Analysis Services started → Ensure that a supported version of Analysis Services is installed and that the service is started. If a supported version of Analysis Services is installed, use the Services Control Panel (Start > Administrative Tools > Services) to start the Analysis Services Windows service. Note: When you use the standalone prerequisite utility, prerequisite checks are run on the current computer only. If you are checking prerequisites for the business intelligence components of Microsoft Dynamics AX, and Analysis Services and Reporting Services are installed on separate computers, the Reporting Services checks will fail on the Analysis Services computer and vice versa. Make sure that you run the prerequisite utility on each computer to make sure that the appropriate prerequisites pass. For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at http://go.microsoft.com/fwlink/?LinkId=211990.
Hi ,
May i know ur data base version is ‘SQL server 2008’ or ‘SQL server 2008 R2’…
Tnx
Lakshmi…
data base version is ‘SQL server 2008 R2’
Darshana
