Hi, when I am installing analysis services configuration of AX 2012 I am facing error. error it is showing in validation screen is " Install a supported version of the Analysis Services component of Microsoft SQL Server."
hi
Only 64 bit sql server analysis server is supported in ax 2012 [^o)].check it out whether your are using 64 bit sql server .
hi rao,
i am also facing same problem when i am trying to install analysis services configuration in ax 2012 in my laptop, how did you resolved this issue?
Thanks in advanceā¦
