Hello Friends,
I have installed Enterprise Portal in AX 2012 with error.
so i want to remove EP from AX 2012. But i don’t know how to remove(uninstall) EP
Please help me How to remove EP in AX 2012
Darshana
Hello Friends,
Darshana
hi
you must reinstall dynamics and select add/ remove option then unselect (Unchekd) EP
Thanks jm,
but when we run setup for remove component there is no option for EP
HI,
If u installed with error then setup will be automatically rollback . so EP is not installed on your AX environment
