I want to setup a testing machine with Windows 2008 R2, SQL 2008 R2, Sharepoint Server 2010 and Dynamics AX 2009. All of these are already installed and running. AX client is working fine. Now I want to install Enterprise Portal on that server. My problem is, how do I make AX setup to realize that Sharepoint and ASP.NET are already there?
When I select Role center and Enterprise Portal in the setup menu and click next the setup complains about ASP.NET and Window Sharepoint Services not being installed and asks me to install it. Unless these requirements are not met I am not able to click Next. Furthermore in AX setup the .NET BC checkbox is greyed out so I cannot select this.
Can you give me a hint on how to get this running?
thanks for the quick reply. But which is the correct version of ASP.NET and do you think this will also solve the problem that Sharepoint 2010 is not recognized?
The previous poster is correct. MS announced compatibility of DAX 2009 with SharePoint 2010 last year in August 2010.
Subsequently they released a patch (or fix) for this compatibility in September 2010. This patch is available for download from PartnerSource and CustomerSource. To download this patch, search for KB 2278963.
