We’re having a problem with our AOS, which is crashing at least once a day. It creates some logs but we couldn’t find what is the cause of this problem.
When the AOS crashes the first log is:
Object Server 03: Dialog issued for client-less session [session number]: Internal error number 119 in the script.
Followed by the messages
Object Server 03: Fatal SQL condition during login. Error message: “[Microsoft][ODBC Driver Manager] Connection in use”
- and -
Object Server 03: SQL diagnostics: [Microsoft][ODBC Driver Manager] Connection in use. Connect information was: Userid = [], Database = [database_name], Server = [server], DSN = [], Other = []
After this nobody can logon in the system until we restart the service.
Does anyone have seen this before?
Thank you
