Experts, what is the External codes linked to each Mode of Delivery for? Is there a web link that I can learn the use of the fields and how to set up the External Codes appropriatly?
The below is the content from the Help
Use this form to set up, define, and maintain external codes for different fields that are used to send and receive documents electronically through Application Integration Framework (AIF).
To use Application Integration Framework (AIF) to exchange documents electronically with an external system, you must configure each document to use internal codes or external codes for its field values.
For example, if a sales order document refers to an item number, you must choose whether to use the item number from the standard tables in Microsoft Dynamics AX (an internal code) or an item number not in Microsoft Dynamics AX (an external code). External codes are used when the values from the standard tables will not be used.
External codes are set up in the form and are associated with internal codes in Microsoft Dynamics AX. You create and maintain external codes in the specific forms that process the internal codes in Microsoft Dynamics AX. For example, both internal codes and external codes for item numbers are set up and maintained in the form.
To create external codes, you must specify a code, a description for the code, and the value of the external code. You must also specify whether the code is an officially recognized standard code, such as EAN, ISBN, or ISSN.
You can create several external codes for the same item, account number, warehouse, unit, dimension, or currency. For example, the item number BR-12 might have one external code value that corresponds to a customer’s item number and another external code value for its EAN number. If there are several standards for the same country code, you can enter the values according to those standards.
