i am trying to use third party DLL. It was regestered fine and i can create automation variables and write code using methods. When i try to run the code i get error message when try to use CREATE:
Could not create an instance of the OLE control or Automation server identified by
GUID={1C0876A6-FF84-48E6-95BE-D3F21C883D14}1.0:{392B78A4-59F5-44DC-A425-9717FDCF1B3E}:‘LpiCom_6_0 1.0 Type Library’.ILPOrderPart. Check that the OLE control or Automation server is correctly installed and registered.
What can be the problem?
