Hi
I need help on the calculation of stock levels
Is there available any NAV tool (report, form, worksheet, … ) to calculate and suggest stock levels based on item history and forecast?
Thanks for your help
Davide Ceoldo
Padova, Italy
davide.ceo@tiscali.it
Navision works on predefined set of info but if u want after the fact adjustment shud be included in deciding what reorder points shud be," By System" then, No. NAV does not have reduction key concepts.
U can use forecast, yes NAV has the facility to plan as per pre-defined safety stock and reorder points. U should contact ur partner to set this for u.
