hai,
iam using navision 3.7 with navision application server ,but i don’t know how to setup automatic backup, plz give solution for this problem
thanking you
hai,
thanking you
There is a nice tool available for backup automation from ExpandIT. Maybe you want to try that. Demo version available.
Kind regards
Walter
Again, I am not related to ExpandIT anyhow.
We use this one. Check it out & It’s free
You could also use hotcopy.
hai thanking u for u responce
hai thanking u r responce,but i don’t about hotcopy plz explan clearly
The most clearly explanation is found in your Navision CD - folder docs. Have a look in w1w1bkup.pdf.
thanks walter
Are you using NAV or SQL database?
I have downloaded this software
and I take the steps from the screen
if i click “Test Script” it could done well
but how to be automatically back up database?
for example I want to back up navision database daily…Automatic
How about starting the script with the sheduler from your OS? (I don’t know the tool Savatage mentioned. But if you have a “script” you should be able to start/run it sheduled, As a batch with some hotcopy parameters would do the same).
just create a schedular it’s automatically update backup every day
But don’t forget a daily check that you have an actual backup.
If the software you’re talking about was the download I posted then on the Finalization Tab there is a button to create a scheduled task
Here are step by steps http://savatage99.googlepages.com/MyBackup.pdf
ok Savatage , Thanks for your answer
i have done it well…
