first off I have done lots of searches and I have not found a solution, I am new to NAV, I wrote a codeunit to bring over data from a third party POS system into navision order processing screen, the data comes over fine, I can release it, then post with no errors.
what I want to do now however is to automate the process of releasing and posting these invoices, how can this be done? any help would be appreciated.
Maybe you can tell us which version you are using.
In Nav 4.0 you can use Job Scheduler whereas in NAV 5.0 and 2009 you can use Job queue. Both serve the same purpose actually _to schedule your job.
Basically there are 3 things need to be done here
Create the job.
Schedule the job in Job Queue
Have Navision Application Server (NAS) installed with JOBQUEUE in parameter
From the requirement, there are two process involved, releasing and posting a document.
To release a Sales Doc, you can use codeunit 414 Release Sales Document.
To post a Sales Doc, you can either use codeunit 80 Sales-Post or report 296 Batch Post Sales Orders.
Depend on your design, you can combine above mentioned process into one job (create one codeunit and run it from Job Queue) or you can create two different jobs.
