Autocomplete Multi-select CE
Hello,
I would like to allow users to select multiple options (multi-select, choices) for an auto-complete control. For example. I would like to select BOTH United States and United Kingdom. I understand that this field has the auto-complete control. Is there something I can do other than rebuild every country in a choices option set?
Hello! If you want to change the out-of-the-box choice field for Country/Region to be a Choices (multi-select) field, you will need to rebuilt it.
Or, search XrmToolBox for a tool… but that’s a dangerous game changing attribute type. Make sure you do a bulk data update if you go that route :slight_smile:
Howdy, @HeidiNeuhauser !
Does the Multi-select field type work on Legacy web forms?
Hi @Allison_Briden ! Sorry for the late reply here! Autocomplete works with legacy forms - have at it, and have fun! :slight_smile:
Thanks for the reply, @HeidiNeuhauser !
I was actually wondering if Multi-select picklists function on legacy webforms. For me it does not and I was wondering if it’s only supposed to work on the Unified interface forms.
:slightly_smiling_face:
I don’t see why they wouldn’t work there - that’s where they were born! Curious what issues you’re seeing…
In Legacy web app, I can’t edit and search for the options.
Accessing the same record in Customer Service Hub app, I can search for and add options to the record.
In the Legacy Web app, there is no control to select options on a multiselect picklist. When I open the same record in the same form using Customer Service Hub, there is a control to search for and select options on the multiselect picklist.
:thinking: hmmm when I have some time I’ll try to play around with this…
@Allison_Briden can you try these steps? The fantastic people at Inogic posted this in 2021 and the screenshots are the “old school” form :wink:
Thank you! I have tried the method of using a SingleLineofText field and applying the MultiSelectPicklist Control to the field on the form. It did not work.
Interesting… do you want to set up some time to do a quick Teams meeting? It’s hard to know through messaging here. If you want to get together and screenshare what you have, I’d be happy to. Shoot me an email: heidi@reenhanced.com.
Updating this thread in case others have this problem but we were able to solve this with a simple setting! If you’re having the same issue, check your settings and toggle “Use legacy form rendering” to No. That should get you rocking and rolling! :star_struck:
