Have anyone experience this?
Setup Item A with tracking dimension is Batch and Serial ( with Serial Number control is tick)
Setup Number Group for Batch as auto generated by reference +number sequence with Allocation option for Physical Update and per quantity is 100
Setup Number Group for Serial as Auto generated by reference+ number sequence with Allocation option for Physical Update and per quantity is 1
Activation for both number groups for all transactions type (sales,purchase,inventory,production)
Try the following transaction in either Purchase Order or Production Order:
Order quantity is 250
Expected Result: Purchase Receipt or RAF will create/assign 250 serial numbers in conjunction with 3 batch numbers
Actual Result: Purchase Receipt or RAF will create/assign 250 serial numbers in conjunction with 250 batch numbers
I believe it’s a bugs from MS but please correct me if i misunderstand Batch and Serial concept in AX or missing any setting up. My AX version is AX 2012 R2 CU6
