Audit Trail
Hello,
I am looking for one report as an Audit Trail for every change in system i.e. opening, receipts, issues, consumptions etc…
Thanks in Advance.
We have built-in Audit trail report under General ledger=> Reports=> Audit trail right. Check it out!
An audit trail for EVERY change will impact on the performance of your system - think why you need it and what you are monitoring before turning on database logging.
Thanks Kiran, Thanks Adam. I am at loss when I see transactions that may not be the same they were originally. These could be movements, transfers etc. To trace this, I need to see things at item level. This report helps when used alongwith the inventory periodic option I had mentioned in my other mail which is not picking the owner of the modification. With the help of you people, I am learning. Thanks. Zaka
