Can we attach multiple purchase agreement in one purchase order in ax 2012 r3?
Bella
Bella
I believe the answer to this is no. You attach it at the header ultimately, and the line has the update features but these are driven by the relationship created in the header. Have a developer look at the references, if it is solely by line then theoretically you can, but the link is header driven if for example you manually create a PO.
Thank for the reply, Adam.
You’re correct. I tried to simulate and we can only select 1 Purchase agreement to the PO and it is in the PO header. If you didn’t attach a PA in PO, the attach PA in PO lines will not be enabled.
Bella
