I have created a Report based on Sales order in which depending on Document status the fields : pickingQty , packingQty, confirmedQty, invoicedQty, outstandingQty should be set to 0 ( showzero is set to no). But i am not able to set my fields to null following is the code that i wrote in my fetch() in report but still i am getting the exact values instead of getting null values. I don’t understand what is wrong in my code. Any help would be appreciated thanks in advance
public boolean fetch()
QueryBuildDataSource qbds;
Query q ;
queryRun qr;
DocumentStatus documentStatus;
q = this.query();
qbds = q.dataSourceTable(tablenum(SalesLine));
qbds.addRange(Fieldnum(SalesLine,CreatedDateTime)).value(queryRange(FromDate,ToDate));
qr = new queryRun(q);
while(qr.next())
salesLine = qr.get(Tablenum(SalesLine));
this.send(SalesLine);
documentStatus = SalesLine.salesTable().DocumentStatus;
quotationQty = (Select qty from custConfirmTrans
where custConfirmTrans.SalesId == salesLine.SalesId
&& custConfirmTrans.ItemId == salesLine.ItemId).Qty;
if(documentStatus == DocumentStatus::Confirmation)
confirmQty = (Select qty from custConfirmTrans
&& custConfirmTrans.ItemId == SalesLine.ItemId
&& custConfirmTrans.InventTransId == SalesLine.InventTransId).Qty;
pickingQty = 0;
packingQty = 0;
invoiceQty = 0;
outstandingQty = 0;
else if(documentStatus == DocumentStatus::Invoice)
invoiceQty = SalesLine.invoicedInTotal();
pickingQty = 0;
packingQty = 0;
ConfirmQty = 0;
outstandingQty = 0;
else if(documentStatus == DocumentStatus::PickingList)
pickingQty = (Select qty from WMSOrderTrans
where WMSOrderTrans.itemId == SalesLine.ItemId).qty;
ConfirmQty = 0;
packingQty = 0;
invoiceQty = 0;
outstandingQty = 0;
else if(documentStatus == DocumentStatus::PackingSlip)
packingQty = SalesLine.deliveredInTotal();
pickingQty = 0;
ConfirmQty = 0;
invoiceQty = 0;
outstandingQty = 0;
else if (documentStatus == DocumentStatus::None)
packingQty = 0;
pickingQty = 0;
ConfirmQty = 0;
invoiceQty = 0;
outstandingQty = 0;
return true;
