Array in ax
How to return a array value in axapta.i.e.how to put in the method.for example if we put as int[] methodName() tell me wheather it is correct it or not
Can you explain in detial?
this may help you http://www.axaptapedia.com/Array_Class
Thank you for your info.I have completed that work in the array part
