I am sorry if this has been asked before, I have looked through the forum but could not find a question that fits my requirements. To cut down on the processing in the finance department, I would like to run an aged creditors/ debtors report by dimension, as each dimension needs to know their contriubtion to the total debtors/ creditors balance.
eg:
Total creditors …100.00
Dimension (a)…050.00
Dimension (b)…025.00 etc
Currently, when I add the dimension to the filter criteron it comes back blank (generated 0 pages) can any one assist with this query. If I am not clear please feel free to identify where the confusion is and I will try to rephrase
The easiest solution is not reports, but Analysis by dimensions feature - but you’ll need someone to set up these, if your’e an enduser - normally you should ask your Partner for help…
I wonder this can be done with analysis by dimensions. The requirement is ageing report filtered on Dimension. Analysis by dimension runs on G/L Entry and the ageing report needs cust. ledger and detailed cust. ledger entry table.
Ricardo: You need to have a customized report which will filter as per your requirement. Contact your partner for customization.
I suspect you used “Global Dimension Code” instead of “Global Dimension Filter” as a filter criterion. Usually users get confused which these two different fields. Using dimension code will return no result you need to apply filter on “global dimension filter” field . Just check if this is the case.
Thank you all for your feedback with regards to my query. I spoke to my partners and they wrote a piece of code for me to be able to segment my creditors. It is working brilliant at the moment …it also lead to the development of an automated banking function that reduces time in data entering bank statements etc
Again cheers …I will be posting another question soon
