Is there a way to have or setup " an Approval workflow for counting journal" ? This approval will be based on amounts $.
If Yes , where can I found it? If No, if someone can briefly explain how we can set it up.
There is no default workflow for counting journal. You need to design a custom workflow (to be customized).
Here is the list of available workflow types http://technet.microsoft.com/en-us/library/dd362043.aspx
Hi, do you know how to setup a workflow from scratch ? is there any sort of doc for that? Thanks
I am not a great believer in workflow in this area. Primarily because it fails the business. I would prefer an alert on the posting of the counting journal and finance to review. Ultimately if you do a count and it is not there and you have lost investment you still have to post it. As part of the process I would expect the counter to review the cost impact because they know if they post a high one they will be asked why, and the cost is usually the prompt for a re-count/check.
Hi Adam,
You have a good idea here and it may be an option. Please can you elaborate on how we can setup the system to approve counting journals with discrepancies based on $ amounts.
That is exactly the opposite of what I said so nothing to elaborate upon. [:D]
