Hello, friends
I have SRS report field in which I have to change font size dynamically for each text part. For example, I have a price label € 25,40. Euro sign uses small font size, price without decimals large one, and decimal values medium one. I have found a function .FontSize and it has different subfunctions. I think insert should be the right one. However, at the moment I havent found a way to correctly apply it. Do you have any experience using different font sizes in one textbox expression? Any help would be appreciated.
=Fields!PriceDecimals.FontSize.Insert(0, 5) + Fields!PriceDecimals.Value + “,” + Fields!PriceNoDecimals.FontSize.Insert(0, 5) + Fields!PriceNoDecimals.Value
Second approach on how to solve it would be by using different text boxes for each price label part, but then the problem is that euro sign could be very far apart depending on the price. For example for a price 5 EUR the label would look like € 5,00, but for price 100 EUR - € 100,00.
Best regards,
Roberts
