I have two database A and B. Both belong to same project the only difference is, B is derived from A and some other Add-On.
Problem is, When I am running any form in B Database that is having Dimension fields with “Caption Class” property, its not showing the respective caption. Its just showing shortcut dimension 1 code.
When, i checked this with debugger on and breakpoint trigger selected, the form didnt go through codeunit 1…
whereas in Database A, the form directly goes to Codeunit 1 CaptionClassTranslate function.
So is there any solution for this…
Or any reason why its not going through codeunit 1.
In Most of the case you will get the error “Object Must Be Saved in Compiled Form”.
But I think, I imported it as .txt format and other thing was that it was not directly executed, so that could be the reason for not showing the error…!!!
But I had really tried all the things and all the suggestions along with my functional team also…
The issue was generated 20 days before i think… (You have replied on mibuso also…)
But obviously, when there is no error message, no body will think about such reason…!!!
