Hi Everyone, how does it work DDEclient can bring? (dynamics ax 4.0**)**
With Ax 4.0 SP2, you should be able to enable configuration keys for DDE. Otherwise if you are in earlier version of Ax 4.0, then you can get a fix from MS to fix this issue.
On another note, personally I have not tried working with DDE (Dynamic Data Exchange for novices) in Ax 4.0. But I heard some negative feedbacks particularly with Ax 4.0.
