API consumption in Ax 2009
hi all,
I am using dynamics ax 2009 i need to integrate the Paytrace APIs with ax. I want to work on credit card merger with ax.
I tried the following
  1. Create HTTP request and send
  2. Catch the response, which will be XML
  3. Interpret the XML to pull the necessary data
By using the below method
Static XML HttpWebRequest(XML _url, XML _parameter)
System.Net.WebRequest webrequest;
System.Net.HttpWebResponse httpresponse;
System.IO.Stream stream;
System.IO.StreamReader streamReader;
xml responseXML;
System.Byte[] arrayOfBytes;
System.Text.Encoding encoding;
try
new InteropPermission(InteropKind::ClrInterop).assert();
//Use .Net framework reflections to make HttpRequest and get the response back
encoding = System.Text.Encoding::get_UTF8();
arrayOfBytes = encoding.GetBytes(_parameter);
webrequest = System.Net.WebRequest::Create(_url);
webrequest.set_Method(“POST”);
webrequest.set_ContentType(“application/x-www-form-urlencoded”);
webrequest.set_ContentLength(arrayOfBytes.get_Length());
stream = webrequest.GetRequestStream();
stream.Write(arrayOfBytes,0,arrayOfBytes.get_Length());
stream.Close ();
httpresponse = webrequest.GetResponse();
stream = httpresponse.GetResponseStream ();
streamReader = new System.IO.StreamReader (stream);
responseXML = streamReader.ReadToEnd ();
streamReader.Close ();
stream.Close ();
httpResponse.Close ();
codeAccessPermission::revertAssert();
catch
throw error(strfmt(“Exception occured during payment process. Url: %1”, _url));
return responseXML;
Still getting the errors in response.
Please suggest some steps.
It will help if you tell us something more about the errors.
i am getting the following error
ERROR~990. Please provide a properly formatted parameter string.|
i have given the parameter string perfectly formatted as described in this book
https://paytrace.com/manuals/PayTraceAPIUserGuideXML.pdf
and checked the response from this link
http://help.paytrace.com/api-response-codes
the below is the main method
public static void main()
str 1000 strtest;
str 1000 strRequest;
//strRequest = “TERMS~Y|EMAIL~nirav.trivedi@indusa.com|”;
strRequest = ‘UN~demo123|PSWD~demo123|TERMS~Y|METHOD~ProcessTranx|’;
strtest = ConsumeAPI::HttpWebRequest(‘https://paytrace.com/api/default.pay’,strRequest);
info(strfmt("%1",strtest));
That the service refuses your parameters doesn’t seem to be related to Dynamics AX. Try the same from Visual Studio if you really want to be sure that it has nothing to do with AX.
You should discuss it with the Paytrac, not here.
