Hi all
Can any one pls tel the exact use of map with small example.
Regards
Manjusha.D
Hi all
Regards
Manjusha.D
Hai Manju,
Maps have similar nodes and properties as a table. In maps, typically only fields are
created and mapped, as properties are already specified at the mapped table. You can
use a map as any table from X++ or objects like forms or reports. Only if using a map
from a form or a report, you should consider creating field groups for your map.
For more information u can go through MSDN & also the following link
thank u
regards
manjusha.d
thank u
regards
manjusha.D
