After Installing AX 2012, I was not able to go to Developing Mode/AOT. Is this something associated with User security.
Any help will be highly appreciated.
Thanks in Advance,
Arunprasath.
Thanks in Advance,
Arunprasath.
did you completed the check list after installation and also check the valid licence information is uploaded or not.
Hi Arunprasath,
Check following -
Thanks all for the quick reply.
Yes i completed the check list.
User is attached to ‘system administrator’
Hari - What i need to check under Admin / License. somethink i need to mark or check in the license file. pl explain…
Arun.
You will need to import the license file, that will give access to the modules.
System Administration → area page → Licensing → License → import license.
