Any posibility to convert the database to Nav 6.0 SP1 from Nav 6.0 R2
Any posibility to convert the database to Nav 6.0 SP1 from Nav 6.0 R2(i.e Degrading)? If yes,please tell me the solution.
Thanks & Regards,
Baba Guru.
How many users you have?
think if you can technically upgrade your database…
You just need to install NAV2009R2 in all user systems instead of NAV2009Sp1
Hi baba guru,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
