has somebody experiences with the following topics:
Automated Testing with NAV 2009
Outsourcing of NAV tests
Some keywords may be: tools, practice/approach, pro & contra, cost & benefit, quality of results …
NAV 2009 has automatic testing options
You can find this on Tools–>option–>Show C/AL Testability properties
Read help files for more info.
can you be more clear What do you mean by this?
I know this function and i got some short introduction. The programming of these tests wasn’t so easy I think. So what are your experiences? How long did you need to get a good testing environment for example for a post-routine?
Outsourcing the application test to a company instead of giving it to an end user.
This is just like normal nav coding but it will take some time to get used of it…
you want to know the outsourcing companies which can do it for you ?
mohana,
I think pduck was rather looking for somebody to perform the TESTING itself, not coding the “tests” - but IMHO it is not worth doing so…
When test part is ready, why to look for someone to run them if you can do it yourself. On the other hand, to outsource everything might be difficult, telling the third part WHAT to test will take more time than writing the tests in-house, where you already have all info - FRDs etc etc…
