I have a customer who tries to build analysing reports. This customer is trying to build up a Column Template that shows: In SalesOrder (Amount and Qty) - In PurchaseOrder (Amount and Qty) and Stockvalue(Amount and Qty) - 6 columns. When using this template in a report, we get correct values in all columns exept for Stock Value Amount.
This column uses Analysis Type Code = Inventory and Analysis Value Type = Cost Amount. It seems that Analysis Value Type = Cost Amount gets it’s values from Cost Amount (Expected). This column will only have values when Item Entries are open (not invoiced) and I can not see that this is correct. I my head, Stock Values are based on Actual Cost not Expected.
Now to my question: Does anyone know how I can get the report to show what I need?
I have tried to create new Analysis Type, but find no Value Type that will give me exactly what I need. I have also tried using other Analysis Types, but they are based on the same Value Type and therefore no help.
Thanking you in advance for your reply.
Toril
