I got below error when I tried to configure services in Microsoft Dynamics Ax Configuration Utility.
"An error occurred while regenerating WCF configuration:
Exception occurred on the metadata service on client or server.
See exception details below:
>Unable to log on to microsoft dynamics AX."
Can any one help to resolve from this issue.
Regards
Zahir
Actually i have deleted appdata… now it’s working fine…!!
zahir
Hi
i have this problem but i don’t now what appdata deleted please can you help me
C:\Users%USERPROFILE%\AppData\Local\Microsoft\Dynamics AX
Check this path is available in ur system and try to delete that ‘Dynamics Ax’ folder .
walido
5
thanks
I have another problem
when i started Dynamics Ax i have this error message
unable to logon to dynamic ax
When i create a new instance (AOS ) I can log on
can you help me
walido
7
Hi
when I click in refresh button i have this error , server, instance name and port tcp/ip is correct
-This the original instance,
walido
8
When I refresh my WCF configuration I have this problem. my Server name, instance name and TCP/IP port is correct
this my original instance
Create one new configuration and then import ur config file back again,try to open ur client.
Kindly check ur AOS is started in services.msc
Kindly reinstall ur AX client and restore ur SQLdatabase.
walido
11
thanks for your help. I reinstall ax
