while Instaling Ep i Got following Error.Help me in solving.
"An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed.
Leaving method UpdateBusinessConnectorProxyAccount
An error occurred during setup of Role Centers and Enterprise Portal.
Reason: An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed. "
regards
P.ram
Ax 2009 or 2012?
Have you checked the error log in the event viewer?
Have you installed the exact pre-requisite for EP?
Hi
I am using Ax2009.Installed prerequest for EP.
regards
P.RAM
Hi Ram,
Did u created a Business commector proxy acount in the administration–>setup–: system
Ya i had created proxy Account ,
Regards
P.RAM
Gone through the previous comments, i’m also getting the same error after completing the Installation of EP, Installed all Prerequisites and Business Connector is also getting Connected.
Hope anyone helps.
Thanks in Advance,
Ansar Basha.S
Hi Naresh,
Thanks for the reply, I have already done the procedure of Uninstalling and Installing Business Connector from Scratch, But it doesn’t work as mentioned in the above link.
Ansar Basha.S
