Original code from Jonathan Archer https://community.dynamics.com/nav/b/moxie4nav/archive/2014/12/08/numbers-to-words
For usage run (sample):
InitTextVariables;
AmountInWords := NumberInWords(123456.78,'Cedis','Pesewas');
Message(AmountInWords);
**NumberInWords(number : Decimal;CurrencyName : Text[30];DenomName : Text[30]) : Text[300]**
WholePart := ROUND(ABS(number),1,'<');
DecimalPart := ABS((ABS(number) - WholePart)*100);
WholeInWords := NumberToWords(WholePart,CurrencyName);
IF DecimalPart <> 0 THEN BEGIN
DecimalInWords := NumberToWords(DecimalPart,DenomName);
WholeInWords := WholeInWords + ' and ' + DecimalInWords;
END;
AmountInWords := '****' + WholeInWords + ' Only';
EXIT (AmountInWords);
**// local variables NumberInWords**
Parameters
Var Name DataType Subtype Length
No number Decimal
No CurrencyName Text 30
No DenomName Text 30
Return Value
Return Type Length
Text 300
**NumberToWords(number : Decimal;appendScale : Text[30]) : Text[300]**
numString := '';
IF number < 100 THEN
IF number < 20 THEN BEGIN
IF number <> 0 THEN numString := OnesText[number];
END ELSE BEGIN
numString := TensText[number DIV 10];
IF (number MOD 10) > 0 THEN
numString := numString + ' ' + OnesText[number MOD 10];
END
ELSE BEGIN
pow := 0;
powStr := '';
IF number < 1000 THEN BEGIN // number is between 100 and 1000
pow := 100;
powStr := ThousText[1];
END ELSE BEGIN // find the scale of the number
log := ROUND(STRLEN(FORMAT(number DIV 1000))/3,1,'>');
pow := POWER(1000, log);
powStr := ThousText[log + 1];
END;
numString := NumberToWords(number DIV pow, powStr) + ' ' + NumberToWords(number MOD pow,'');
END;
EXIT(DELCHR(numString,'<>',' ') + ' ' + appendScale);
__**// local variables NumberToWords**__
Parameters
No number Decimal
No appendScale Text 30
Return Value
Return Type Length
Text 300
Variables
numString Text 300
pow Integer
powStr Text 50
log Integer
//Global Variables
// OnesText Text 90 | Dim:20
// TensText Text 90 | Dim:10
// ThousText Text 90 | Dim:5
**Set Dimension on the Property Page For The Global Variable**
OnesText Text 90
TensText Text 90
ThousText Text 30
AmountInWords Text 300
WholeInWords Text 300
DecimalInWords Text 300
WholePart Integer
DecimalPart Integer
InitTextVariable()
OnesText[1] := ‘One’;
OnesText[2] := ‘Two’;
OnesText[3] := ‘Three’;
OnesText[4] := ‘Four’;
OnesText[5] := ‘Five’;
OnesText[6]:= ‘Six’;
OnesText[7] := ‘Seven’;
OnesText[8]:= ‘Eight’;
OnesText[9] := ‘Nine’;
OnesText[10] := ‘Ten’;
OnesText[11] := ‘Eleven’;
OnesText[12] := ‘Twelve’;
OnesText[13] := ‘Thirteen’;
OnesText[14] := ‘Fourteen’;
OnesText[15] := ‘Fifteen’;
OnesText[16] := ‘Sixteen’;
OnesText[17] := ‘Seventeen’;
OnesText[18] := ‘Eighteen’;
OnesText[19] := ‘Nineteen’;
TensText[1] := ‘’;
TensText[2] := ‘Twenty’;
TensText[3] := ‘Thirty’;
TensText[4] := ‘Forty’;
TensText[5] := ‘Fifty’;
TensText[6]:= ‘Sixty’;
TensText[7] := ‘Seventy’;
TensText[8]:= ‘Eighty’;
TensText[9] := ‘Ninety’;
ThousText[1] := ‘Hundred’;
ThousText[2] := ‘Thousand’;
ThousText[3] := ‘Million’;
ThousText[4] := ‘Billion’;
ThousText[5] := ‘Trillion’;
