Amount aggregation query
I’m trying to build a query that aggregates the amounts per combination of G/L Account, Dimension and Posting Date.
CurrencyCode and OrderAmount are fields that we’ve extended the G/L entry table with.
The problem I’m facing is that the same amount is shown per aggregation.
Can I get some pointers on how to structure my query?
Here’s the BC navigate view.
And here is the result of my OData query.
And the query.
query 70304300 "G/L Outgoing Balance_SCY"
    Caption = 'G/L Outgoing Balance';
    OrderBy = ascending(PostingDate, AccountNo);
    elements
        dataitem(Dimension; Dimension)
            column(DimensionCode; Code)
                Caption = 'Dimension Code';
            column(DimensionName; Name)
                Caption = 'Dimension Name';
            dataitem(Dimension_Set_Entry; "Dimension Set Entry")
                DataItemLink = "Dimension Code" = Dimension.Code;
                SqlJoinType = InnerJoin;
                column(DimensionValueName; "Dimension Value Name")
                    Caption = 'Dimension Value Name';
                dataitem(G_L_Entry; "G/L Entry")
                    DataItemLink = "Dimension Set ID" = Dimension_Set_Entry."Dimension Set ID";
                    column(PostingDate; "Posting Date")
                        Caption = 'Posting Date';
                    column(LCYAmount; Amount)
                        Caption = 'LCY Amount';
                        Method = Sum;
                    column(OrderAmount; "Order Amount")
                        Caption = 'Order Amount';
                        Method = Sum;
                    column(OrderCurrencyCode; "Currency Code")
                        Caption = 'Order Currency Code';
                    dataitem(G_L_Account; "G/L Account")
                        DataItemLink = "No." = G_L_Entry."G/L Account No.";
                        column(AccountNo; "No.")
                            Caption = 'G/L Account Number';
                        column(AccountName; Name)
                            Caption = 'G/L Account Name';
