I am making some changes to the Customer aging report (AR/Reports/Status) . The request is to be able to see the cross company results. I did the below steps and it doesn’t seem like adding the companies to the CustAgingReport query.
- Changed the AllowCrossCompany property of the CustAgingReport to “Yes”
2). With the above change I do see the ‘Conpany Range’ tab in the Select query wizard screen when clicked on the Select button is clicked on. I am able to select the companies that I would like to search in
3). Created a new method in the CustAgingReportDP class to add the selected companies to the query. Below is the code
private void masAddCompanyRange(Query _query)
container companies = this.parmQuery().getCompanyRange();
int i;
DataAreaId companyLocal;
QueryBuildDataSource qbdsLocal;
//_query.allowCrossCompany(this.parmQuery().allowCrossCompany());
_query.allowCrossCompany(true);
qbdsLocal = _query.dataSourceTable(tableNum(CustTable));
for (i=1;i<=conLen(companies);i++)
if(conPeek(conPeek(companies, i), 2))
info(strFmt('1%',conPeek(conPeek(companies,i), 1)));
companyLocal = conPeek(conPeek(companies,i), 1);
_query.addCompanyRange(companyLocal);
//_query.dataSourceName('CustTable').addRange(fieldnum(CustTable,DataAreaId)).value(queryvalue(companyLocal));
this.parmQuery(_query);
but while debugging when I look at the query text I don’t see the range has been added to it. The query looks like this
SELECT * FROM CustTable(CustTable) WHERE ((AccountNum = N’468057’ OR AccountNum = N’407178’)) AND ((CustGroup = N’20’))
4). I have tried using the line of code
_query.dataSourceName(‘CustTable’).addRange(fieldnum(CustTable,DataAreaId)).value(queryvalue(companyLocal)); and it does the range but at the end it is throwing the below error
“Filtering at the data source level is not allowed for a cross-company query.”
Am I missing something?
Dave
