Allow user to access different company
Hello,
I am changing the rolse for some users which should also giuve them access to a different company.
However, after a single user sync nothing really has changed.
Do I need to run a full synchronization process to reflect the changes?
Many thanks,
Frank
You should not have to. What were the user’s roles before and after your change?
These are all customized roles. However, the user had very limited roles in company A, the roles in the new company B are much more powerfull.
Do I need to sync for each company?
Many thanks again,
Frank
Have u set role properly .Kindly try to sync again.
