Hi… you have seriously missed something very important about AX 2012… that’s the trick that data AND program code are both now stored in database
The very easiest code backup option for AX2012 is to make a DB backup, but along with this you will back up also all data, so as you will restore the DB, data will be restored along…
Next and the most advisable option is to make backups for the necessary application models by exporting them with AXUtil tool and reimporting back when necessary.
The last, but the least advisable would be to export XPOs for the things you want to make backup for, but that’s slow and unnecessary, but still technically doable.
You mean to take the backup we have to take the back up of db (both code backup with labels as well as data back). But the for me i want to create a instance with out data and when we take the db back up its taking long time and as well as space. Is there any other steps to take the app code backup from production environment and restore it in test environment as I want both the production live environment as well as test environment to be same.
