AIF Document wizard ax2009
I want to run
  1. From the Microsoft Dynamics AX menu, point to Tools, point to Development tools, point to Wizards, and then select AIF Document Service Wizard. The Welcome screen appears
But still the wizard isnt available from above options. Do i need also X++ source code?
MS site says:
Prerequisites
To complete this walkthrough, you will need:
  • Microsoft Dynamics AX
  • A license file that has access to AIF
I am having these licenses: why isnt the wizard not available? DO i need also X++ Source code?
Application Integration Framework
Application Integration Framework Web Services
Windows MorphX Development Suite
Yes, you need “X++ source code” license; “MorphX Development Suite” doesn’t cover things such as classes.
